Dell 2001fp backlight
alexpronko
I wonder if anyone here owns a perfect Dell 2001fp. The first one I've got had terrible backlight problem. The replacement is better but it still has a little "bleeding" in the top right corner. I strongly suspect that it is thermal related as that corned does get much hotter than any other part of LCD. I have Viewsonic VP2000s that basically uses the same panel and it also gets hot but not that much as dell, however it's backlight is nice and even.
How are your 2001's guys? Does every 2001 have small bleeding in the top right corner or most of you have nice even backlight.
I ask because I wonder if I should get 2nd replacement or if this is the way it is with 2001's and all of them have small bleeding.
My 2001FP had very minor backlight leakage in the upper left corner (only noticable when looking at a black screen) ..I just couldnt get used to the poor black levels it had with dark games (Doom 3 /FEAR/ HL2 etc.) ..Returned it for a refund.
Revision / Mfg date info:
What did you replace it with?
