Sparrow_69
- Jan 20, 2004
I ordered this lcd on nov 25th and just received it this morning. It was well packaged in the usual dell fashion. I however don't really like the fact that the lcd is facing downwards in the box. It was however well protected with a plastic sheet over the screen and it was in a styrofoam type bag. BTW, yes, the vga cable was already attached. After hooking everything up, my first impression is that the lcd is really big compared to my 17". The monitor itself is really good looking. Thin black bezel with silver stand. It also has 2 usb port on the side of the bezel. I don't think I would ever use them since I would then have wires hanging from the side of the screen. Would it have been so hard to put it in the base of the screen? I initially thought that the dvi and power cable would hang down from the lcd an be seen, (they attach directly to the bottom of the panel, not to the base) but when the cables are put through the rubbery sleeve in the back of the stand, you can pull them tight enough so they aren't seen.
Now, for the interesting stuff. The colors are extraordinary. They are very bright and everything is very colorful. I have my brightness set to 25%. I've so far left the color settings at the default since I really like what the colors look like. As for contrast ratio, its also excellent. Blacks are very black and not "bright" as with some cheap lcd's. I know about blacks being very poor. My first lcd, a samsung 570v was a tn type panel. It had very poor blacks. Unfortunately, it was the best lcd on the market at the time. Furthermore, the viewing angle is very good horizontally and vertically. Even at almost 180degrees, the screen is still very clear. Furthermore, when normally viewing the lcd, you cannot see any difference in brightness in the screen itself.
Now, for ghosting. I just received the lcd this morning, so I'll give you my initial impressions. I tried a bit of Far cry, CoD, D3 and UT2004. As with my other lcd (25ms pva) ut2004 doesn't in my opinion, have any ghosting. It really depends on the game however. Far cry ghosts only on objects that are more "earthy in color". I would say that the ghosting in Far cry is minor. As for D3 and CoD, I would say that plain and simple, this is come ghosting. Mainsly due to the fact that there are a lot of greys in both the games. However, they do ghost less than my 25ms panel. When ghosting does occur, the ghosted image is less dense and more see through compared to my other lcd. I should also add that there is no backlight leakage whatsoever. I will play around with it a bit more tonight to get a better idea of how it performs. I should also add that I paid 585$ CAD with tax and shipping. Dell was offering 50$ off and free shipping. Also, I had a 15% off software and peripherals coupon.
Here are a few pics if anyone is interested:
0% brightness:
100% brightness
The digital pictures exagerate the difference in color saturation between the 2 lcd's. However, there is a difference. The samsung has more saturated colors, the dell is brighter and shows more details.
0% brightness:
100% brightness
