Dell 1704FPT or 1905FP?
Hi,
I need to pick up two new monitors, one to share with my mini and pc and one just for the pc for when I want two displays on that. What would be better of the two options? I understand they are the same res, so it's confusing which to get. They are on special and I need two, so this has narrowed my options.
BTW, I do design work, are these going to work well for that?
Thanks!
Definitely the 1905FP. The 1704FP or whatever is a TN panel, as far as I know. If you're doing design work, you want the full 16.7 million colour spectrum, not just 16.2 million. It is a re-badged Samsung 193P, depending on the revision. If you get the other revision, you still get an 8-bit AUO panel, and it is said to be a little faster.
Well I ended up getting two 1905FP on sale and minus ebay coupon. Hearing that the 1704 was a TN panel and that the 1907 is as well helped me decide. Just wish it looked like the new models.
