Deliding Skylake today
alxlwson
You Know Where I Live
Yikes, but this 8°C hotter core is driving me nuts. It's time to rip her top off and squirt mah goo all over her naughty bits.
Pics to follow
She's naked!
Well, didn't solve the hot core. Core #1 several degrees higher than the others. HOWEVER!!! I dropped 18º load temps :D Very happy with that.
This was the most nerve-wrecking experience I've ever done. I never want to do it again. Next platform will be HEDT for this reason alone if they don't solder the consumer chips next round.
I used Gelid Extreme III for my TIM. Perhaps later I'll get some CLU if I see my temps start to rise over time.
did u put lid back on, or direct die cooling? I'm also stuck at 4.5ghz on my 6600k but I only have a cheapie H70i Corsair cooler shoved into a mITX cube for cooling. Did you get a higher oc?
No, didn't do direct die. From what I've read, you only lose another 1-2°C with doing that, plus the extra risk, and that requires also spending some extra money that I dont wanna spend ;)
Haven't attempted more OC yet. I'll be doing some more OC attempts next week when my GPU block comes in. I need to be certain that the increased water temps from gpu won't affect the cpu OC. I'm sure I'm just being silly about that, but oh well ;)
My x71 comes today. Gonna see what kind of baseline water temps I get with just the cpu and the extra EK XE 360 that came in yesterday
Could be the sensor is not as accurate.. I assume you are not using the GPU or lightly using it.
GPU not in the loop yet. Block is backordered from PPCs. Should be in sometime next week hopefully
