About 1 week a bout an error started to appear every time i was trying to copy something on my hd.The error message is following :
http://www.pctech.gr/viewthread.php?action=attachment&tid=19317&pid=204850
A lot of people told me that my hd is a bout to fail.
I have done, scandisk,defragments, western digital diagnostics. No errors, no bad sectors.
I read on microsoft that it could be the cables , instead of 80 to use 40 wire cables. I never changed the cables so this is not for 100% the problem.
I tried several things. Like:
1)Disabling "Allow Indexiing Service to index this disk for fast file searching".
2)I also enabled and disabled from registry: LargeSystemCache , but still the
messages were appearing.
3)I did a scandisk, and also the diagnostic tools from West. Dig. but didn't show
any error or but sectors on the disk
4)Enabled/disabled Direct Memory Access
5)Checked the IDE cables . Actually the cables CANNOT be cause i did never change
them, or pluged them out
6)Reinstalled SP4
7) Reinstalled windows 2000 prf
8)To finish a diagnostic test from DOS (Did it just under windows)
My disks options look like that:
http://www.pctech.gr/viewthread.php?action=attachment&tid=19317&pid=205106
and the second one:
http://www.pctech.gr/viewthread.php?action=attachment&tid=19317&pid=205115
Now some things about my system.
I am using Windows 2000 Prof. with SP4
Intel P4 2.66ghz
Asus Pt533 Mobo
2x256 Rdram Samsung
1x80gb WD
1x160gb WD
Both are ata-100
My windows are isntalled on the 80gb one, the one who has the problem is the 160gb disk.
I use ntfs on the 160gb disk , and its just 1 partition.
The error appeared from nothing actually. i cant remember installing something that could cause that. The problem is i cant format the disk cause i have about 100gb on it that i am not able to back up because i dont have another disk with so much capacity.
Also direct memory Access is enabled
Do you suggest anything that i could try ? Do you think that reinstalling windows would help ? Is there any fix available about it?
Could it be my hardware or software? what does the error seem to be ?
6)Reinstalled SP4
and the second one:
Intel P4 2.66ghz
Asus Pt533 Mobo
2x256 Rdram Samsung
1x80gb WD
1x160gb WD
Both are ata-100
