Delayed write error on client comps while running ntbackup
Menelmarar
When running ntbackup on Server 2003 with an XP machine editing files. Sometimes will cause a delayed write error on Windows XP and loose all data for that file.
Isn't ntbackup suppoed tow ork even though people are using files?
ok maybe I should elaborate. I do have a vague understanding of what write caching does.
Even though I think ntbackup should be handling this
Windows XP seems to be using write caching for network folders as well as the local drive. Is there a way to disable write caching for remote folders? or will disabling it on the local drives disable it for all?
