I put together a new server last week and i've been setting it up/moving things over to it since then. Its been running fine since i put it together, but today i shut it down to put some new fans in there and when i boot it up i get all kinds of warnings stated that array 1 & 2 are degraded, i have 3 raid 1 arrays. I'm not sure where this came from, as i've been checking the arrays religiously and never seen a problem. I don't know much about raid, but what confuses me is that when i saw this problem i shutdown the computer and rebooted it into the controller bios where it tells me that array 1 & 2 are rebuilding, which i thought only happened when i replaced the bad drive.
My mobo is a supermicro x7dbn, the controller is a aoc-usas-s8ir, the drives are ST3750640NS (750gb seagate Enterprise Series).
If you have any advice i would really appreciate, also if any of know how to determine which drive has failed within the array that would be great (the controller uses adaptec software)
Thanks alot
James
oh, i have no hot spares set up yet either
Thanks alot
James
