PerfectDisk ftw...
O&O can optimize your disk to how often you use a program.XP's default defragmenter.
IMO getting a defrag app, antivirus, firewall, spyware app, tweaking apps, and a whole lot of other "optimizing software" will just slow down a PC rather than improve it. Now all I have on my computer are essential programs, nothing else, and my computer is working just fine.
Are there actually benchmarks out there that these defragers are more effective? What proves that diskeeper or O&O are better? I know that they're way faster than the XP defrager, but besides that?
Diskeeper has done that for 8 years now, and PerfectDisk does it as well.with O&O you can also schedule offline defrag which will allow you to defragment the drive before the OS loads so system files can be moved around.
I know, I was comparing it to the Windows XP defrag :}Diskeeper has done that for 8 years now, and PerfectDisk does it as well.
PerfectDisk is the only thing I recommend, period.
As for stopping, it hurts nothing; it merely stops the defragmentation process wherever it was. You can always start again later, and the defrag app will typically do another analysis pass, note everything that's notfragmented, and start from that point - it won't typically remember where it left off, and since it's running another analysis pass, that would be pointless anyway.
It's best to run an analysis pass before every defrag, especially if you're trying to pick up from where you left off. This ensures the total defragmentation of a drive at any given time when the defrag is begun.
In my own testing, PerfectDisk (v8 is the latest) stomps Diskeeper (v2007 is the latest) and O&O Defrag (v8.5 is the latest) into the ground, both of 'em. Neither of the competitor's products could defrag a specially created 20GB image file I have with 259,000 fragments from 4K files.
I created it specifically for testing defragmentation software using a tiny command line defragger tool that has a "reverse" mode and can purposely fragment a drive like crazy - it's called a "shotgun" fragmenter because when it's done, it's like taking all those files, putting them on CDs/DVDs, and holding it at the end of a 12 gauge shotgun and pulling the trigger: the files get blasted all over the place in tiny pieces.
PerfectDisk v8 defragmented the entire partition in 1 hour 5 mins and in one single pass. Diskeeper v2007 took over 9 hours and required 7 passes. O&O v8.5 took 12 hours and 17 mins and 11 passes to fully defragment the drive back to 0% fragmentation.
This was all done on a Core 2 Duo 1.66 GHz laptop, 2GB of PC2-4200 RAM, 160GB SATA I 5400 rpm drive with XP Pro SP2, NTFS.
Maybe someday I should post the results with a bunch of pretty piecharts and schtuffz...![]()
and you can set it to sort the files by Name, Access date and Modified date
This free tool also performs offline defrag: http://www.microsoft.com/technet/sysinternals/FileAndDisk/PageDefrag.mspxwith O&O you can also schedule offline defrag which will allow you to defragment the drive before the OS loads so system files can be moved around.
That's all sounds great, the more features it has the more people will fall for the defragger and the better it will sell, but what I want to know is how much of an advantage does this give over the default XP defrager? When I have 400 gigs of data and software will it make a big difference that a few megs of system files can be moved around?
The default defrager on windows XP defrags, and I am convinced that no other defrager will give me an extra 10fps in my fps games, or make PS load 2 seconds faster. If anyone can convince me otherwise, I might get another defragger software, but I don't think that's likely to happen.
bbz_Ghost, can you test Auslogics Disk Defrag with your little test? It's free and is really quick, but I'd like to know how it compares with the commercial defraggers. http://www.auslogics.com/disk-defrag/
You can do the same thing with the built-in WinXP defrag applet.I started using JkDefrag because ... and theres a command line version included so you can just schedule a task or make a script to run it whenever.
Thank you.3 hours 17 minutes, compared to PerfectDisk again pulling out the win in 2 hours 2 minutes (again, I'm on a slower machine now, nowhere near as fast as that original Core 2 Duo and DDR2 RAM sooooo...
Again, YMMV.
And besides, BootVis is for XP only, isn't it?
