i know removing the hd cage to make the H100 fit is an option but i don't want to do that. i've also know about the mod using cable ties.
i was wondering if it can be installed by just screwing in one side and just using 2 screws (probably with a washer and some padding) through the top mesh at the other side, thus using only 6 screws? i have an h80 and h100 that i haven't opened yet, so just wondering if i can use the h100 this way or just go with the h80.
also does anyone know the cooling difference between the two coolers when used with a 3770K overclocked to ~4.6GHz?
