Define 7
djstarfox
So, where are all the Fractal Design Define 7 builds? There are dozens of reviews out there (both professional and consumer), but I have yet to see any mods/builds/custom ideas. Anyone care to post pictures of your Define 7 / XL cases?
I've posted mine a few times, Define 7 XL:
Slightly older picture before I got a little more RGB at the end of last year. I have 7x 3.5inch HDDs in this case along with 4x NVME SSDs.
I love this case.
My whole desk setup if you're curious:
Thanks for posting. I see a lot of dust on the front fins already... I hear both side of the front case door issue... Does keeping it open really help your temps?
The dust isn't that bad, it's on the weird plastic thing that's infront of the filter and I don't clean that off, just the filter behind it. Which really hasn't gotten bad enough to need cleaning since I moved the case off of the floor.
And yeah, door open makes a pretty big difference. I don't have any reason for a 5.25 bay and if the meshify variant existed before I bought my case (last summer) then I would have gotten that instead. I tuned my fans enough that even with the door open you can't hear a thing at full load.
