I've had my Gigabyte 8800GTS 512MB for almost a year now and I've had a problem with it for a long time. I have to manually set the fan speed on the card higher (at 70 %) or it gets graphical artifacts and the computer freezes (When playing 3D games). Should this happen!? It's running at around 54 Celsius at default 37 % fan speed at idle and when playing it goes to maybe 65 or so and that's when the card goes haywire. I have to raise it to 70 % to keep it below 60.
I've been fine with this for a long time, though I haven't like it. However I'm getting more and more frustrated by the fan noise and with the 180.xx drivers they have for some reason disabled manual fan speed settings so I can't use any drivers newer than the 179 =(
Is this normal for 8800GTS? (It's factory overclocked by Gigabyte to 700/1000 (not sure about the shaders but I think they are a bit overclocked as well) I haven't overclocked any myself just use the speed it came with from the factory.
