Trying to upgrade a laptop from 16GB to 64GB. The stock RAM is 2x8GB DDR5-5600 (generic brand as far as I can see). I have a set of Crucial 2X32GB DDR5-4800 from an older laptop. When I swap it in, the laptop will not power up. No sign of life whatsoever. I thought maybe I killed it somehow, but placing the original RAM back in, it works as normal. I've repeated this experiment 3 times now with the same exact result.
I have no other device that takes DDR5 SODIMMs, so I can't test the Crucial 64GB kit. But it was a working pull so hard to believe it is a problem. Also, I figured an incompatible RAM would at least try to start up and fail POST or something. This doesn't even give me a single LED showing it is even trying to boot at all.
What could be happening here? Any ideas?
