Somnambulator
- Apr 13, 2008
Running Main PC in sig. note the Vista 64.
2 weeks after shipping my 9800GTX to evga for step-up i finally received the GTX260. however, upon installing the drivers and rebooting, Vista loop crashed at desktop. continuous crashing and rebooting PC. so, uninstalled drivers, rebooted to safe, driver cleaner, reboot, installed latest 177.41 WHQLs and rebooted. same result. same process, installed drivers off evga disc...boots to Vista into a GPU recovery msg, it quickly reloads Aero, and Windows seems fine. quick 3dMark06 test...slow off the bat. scored 4500 at default settings. wtf?
so, same reinstall process, go with slightly older 177.35 WHQLs, same exact results as CD drivers. GPu recovered at logon, 3dmark06 scores 4500. (might be same drivers, didnt check). at least Vista works...so i try going back to the latest 177.79 beta and 177.41WHQLs and niehter loads vista without loop-crashing again.
fan is working but havent check temps. i dont imagine the problem laying here. Power issues? 750w Quas Silencer has 60amps on single rail, dont think thats the issues either. can only conclude either the 177 driver issues are extremely worse than i've read or my card is DOA.
I know my Vista install is legit and very tidy. i uninstall all apps with YourUninstaller and run CCleaner regularly. 9800GTX ran great 2 weeks ago. i dont have another card to run but i may rent a BFG 260 from bestbuy and make sure it's my card.
i've heard there are some driver issues specifically b/w the GTX260 and 177 series drivers. im guessing these issues arent as bad as what im experiencing, and im concluding i got a bad card.
gotta add i uninstalled RivaTuner and all nvidia apps. Sometimes after rebooting from a driver install, Vista sees my device but doesnt load drivers for it. ie after installing random 177 driver, i reboot and Vista dev manager shows "VGA Device" or w/e. then i reinstall the same driver, reboot, and it shows up fine. an X-Fi PCI card i had used to do this before completely dieing.
any objections or suggestions?
