GTP_driver
- Jul 30, 2001
What's the default setting for Mushkin Lv2 PC3500?
2-2-2-5, 216 @ 2.7v?
nice, I'm gonna try cranking mine upto 2-2-2-5 210MHz later todayOriginally posted by GTP_driver
i currently have 4 sticks of lv2 pc3500 and 2 of them can run 2-2-2-5, 222 @2.9v passed memtest 10times
however, my motherboard (IC7-G) only goes upto 2.8v, but I'm hoping when I update the BIOS, it will have some more options
I've heard BH-5 sticks can handle upto 3.2v
Yeah, I wouldn't run 3.2v for a long time, but I'd like to at least have 2.9 and 3.0 available.Originally posted by burningrave101
Yes they can handle up to 3.2v but i probably would feed them that much for a prolonged period. Just set your divider to 5:4 so you can keep the RAM speed down. Winbond BH-5 has 5ns 200Mhz chips so you have to crank up the voltage some though to around 2.8v to get the DIMMs stable with 2-2-2-5 timings and able to overclock to their rated speed of 217Mhz.
I'll be flashing my BIOS tonight, so we'll see.
Originally posted by Volkswagen
2 days ago i got my 2 x 512MB DDR 400 Mushkin Level 1 and set it to Turbo timings in the bios and it running 2 2 2 5 rock stable and on stock volts in my shuttle. <Happy>![]()
Originally posted by onetwo
I have the PC3500 L2 and I only get 2-3-2-6 @ 217MHz and 2.8V... anything higher than this results in errors, even with higher voltage.
IMO, this RAM is way overhyped.
No.Originally posted by onetwo
Or is it reasonable to live with settings that generate nearly 500 errors per pass in memtest, even though it boots and allows me to play some games (but rarely finishes graphics benchmarks)?
