Deeper Inside Intel
Shintai
Semiconductor Engineering .:. Deeper Inside Intel
Quite some gold nuggets in it and worth a read.
Mark Bohr, senior fellow and director of process architecture and integration at Intel, and Zane Ball, vice president in the Technology and Manufacturing Group at Intel and co-general manager of Intel Custom Foundry, sat down with Semiconductor Engineering to discuss the future directions of transistors, process technology, the foundry business and packaging. What follows are excerpts of those conversations.
That was a very interesting interview. EUV power output still seems to be a problem, so it's not going to be ready as 7nm development continues. FinFET might be around for a few more nodes. The interviewer didn't push new materials very much, but Intel is still calling several likely candidates "immature". That is confusing, and hopefully just misdirection.
Intel Custom Foundry EMIB
A bit more on the EMIB.
Embedded Multi-die Interconnect Bridge (EMIB) is an elegant and cost-effective approach to in-package high density interconnect of heterogeneous chips. The industry refers to this application as 2.5D package integration. Instead of using a large silicon interposer typically found in other 2.5D approaches, EMIB uses a very small bridge die, with multiple routing layers. This bridge die is embedded as part of our substrate fabrication process
Bye, bye interposers.
