HardOCP News
[H] News
- Dec 31, 1969
Shopping for a new cooler to keep your processor temps in check? Overclockers Club says that, while the Deepcool Frostwin is well designed, it just wasn't up to the task when it came to overclocking.
The twin tower design looks like it may have a lot to offer in the way of performance with the push/pull configuration. The cooler is equipped with a total of four heat pipes that are roughly U shaped. Each of the four heat pipes extend one half inch above the top of the towers and run parallel to one another up both sides of the cooler. The base itself is made up of the typical mixed metal combination of aluminum for the top and copper for the heat pipes along with integrated fins for added heat dissipation.
