Decoding A3C from optical input on Audigy 2 plat.
JRT
Hey All,
I have an Audigy 2 Platinum, with the Live Drive Bay.
I am trying to input AC3 from my Xbox 360 into the Optical-In on my Audigy but it will not decode it.
I want to bring this source in from the 360 and decode it to 5.1 analog out to my 5.1 headphones.
Anyone know of a way to decode an AC3 from this optical input?
I thought AC3Filter would work but, it only decodes DVD and movie files.
Anyone have a filter that will work?
Thanks A Lot.
You should be able to decode from external sources going to Creative's Audio Console->Decoder tab -> Use built in decoder
SPDIF I/O tab-> SPDIF Input -> SPDIF-In Decode
Did you use those settings?
LOL Thx alot man.
You know I have never even used that console.
I didn't even know it was there till you said something, then I remembered seeing it once.
All is good now. :D
