decisions decisions
el_lance_o
I don't know what to do. I'm not sure whether to get either a geforce 6600 gt or an athlon 64 setup with a 2800 and a nforce 150 or so. My system's in my sig. I think I can wither get the 6600 gt and maybe have my system be bottlenecking the card, or get the 64 system setup, and have my video card bottleneck my system. Oy I don't know what to do, any thoughts or ideas?
I would go with the video card probley. You will get a lot better directx 9 performance in games, I dont think that the processor upgrade will give you that much more performance since you are going to get a 2800+ 64 from a 3200+. You will see some performance gain in that upgrade, but I dont think it would be enough to warrant an upgrade, wait for awhile and get a 3000+ or 3200+. Plus, with getting the videocard you dont have to worry about your processor/motherboard becomes obsolete later. AGP will be in motherboards for awhile so you can always carry the GPU over put with a new processor/mobo you could run into some complications later down the road when you upgrade that.
oh yeah that's right. Yeah I guess I'll go for the video card whenever it comes out for agp. Besides, I probably can hit 2.4ghz with this so it won't be a real bottlneck to the system at all, especially with dual channel. No all's I gotta do is figure out when the agp 6600gt's are coming out. Or maybe I can get a 6800nu.......... eeh
Definitely get the vid. card. With my POS system the vid card made a huge difference in games. I decided to get a bfg6800 as the first step in upgrading my system. The difference is amazing. I can play FarCry at 1280 with 2nd to the highest settings at very playable fps rates. I expected an increase in performance but was pretty shocked with the increase that I got. I would ventrure to say that with alot of games the vid card is the driving factor over the CPU as far as performance is concern. I expect an upgrade in performance once I buy a new CPU but I'm not sure that the benefits will equal what I got by just upgrading the video card.
