gigglebyte
- Jan 18, 2001
ok..I have been looking to upgade my Ti4200 for a while now and the time has come. before somebody says read the furums before you ask the question...I have read them and have narrowed it down to a couple of choices but I am requesting some info/guidence on which one to get.
First thing off money is not going to be that big of an issue...do I have unlimited funds? not by a long shot...but I can easily afford the card but want to get the best bang for my buck so VALUE is more important than actual end price.
When looking at the specs it looks like the 9700Pro holds its own very well with the 9800Pro and it looks like there is only about a 10FPS difference between the two so I have to wonder if I should spend the extra bucks for the 9800 or save my shillings for some other toys
Now to throw a curve ball into this...I would also consider the AIW versions of either one and get rid of my LeadTek cap card (as nice as it is it does take up an extra slot). Now with this all said what are the big differences between the 9700/9800Pro cards and on the AIW side do they have the same hardware or different?
