Decision: P4 2.4A Prescott or 2.4C ?
DDrasus
I need to choose one of these asap. Which is a better processor? I'm guessing the 2.4C will O/C considerably better, and apparently the 2.4A has no HT. What should I go with?
You wordage is very confusing. The A class were the first P4s, and they ran on a 400 MHz bus. You currently have a B, which is a step up....on a 533. The newer ones, on the C class, run on an 800 Mhz bus and are HT enabled. I didn't think Prescotts ran any slower than 2.8 GHz.
Intel recently released a so called "P4A Prescott" at 2.4 ghz. Its a confusing naming convention to say the least. Check it out at newegg.
they have a Prescot 2.4A. it's rather confusing, it runs on a 533FSB, and has no HT, it is not the ORIGINAL 2.4A. stupid Intel :rolleyes:
anyway i say get the 2.4C the Prescots run too hot IMO.
There are the new Prescotts out with only 533 fsb and no hyperthreading. Stick with the C series chips with hyperthreading. The 533 fsb Prescotts are not worth the money.
I did a little research and found the explanation. On all official documents, including their roadmaps, the Prescotts are listed at a minimum of 2.8 Ghz. Some however, do not clock to that speed very well, so they dropped them down to 2.4 and released them. If your planning on overclocking, that is an extremely clear message that you shouldn't buy it.
Get a Northwood. In my mind, you shouldn't get Prescott until at least LGA775 socket comes out.
