Deciding to oc my old card......help
Ok, so im gonna oc my radeon 9500np 64mb just a little bit....
Can i do this by just going into the cards direct 3d properties and raise the anti-aliasing and/or the anisotropic filtering up from 2x? Also, can i change the texture quality and minimap detail level down to performance instead of quality? Also, should my smart shader effects be on "no effect"?
Or should i just use ati tool?
Setting the details from quality to performance should give you a big speed boost. You can also try bumping up the mem and core speeds by 5mhz incriments.
bumping the mem in atitool you mean?
