Deciding on which 37 inch to get
corup7ion
Hello, I've been thinking about getting an olevia recertified 37 inch, and had a few questions..
Firstly, Here it is.
http://www.newegg.com/Product/Product.aspx?Item=N82E16889022049
They have the same one but in a dark grey or black. Which do you personally think looks better?
I'm actually going to mainly be using it for a computer monitor, but also for Comcast cable , and maybe some playstation.
Is it just me, or does the silver one have no cable port? and the black one does? in the pictures, its on the side at the top.. looks like the silver one doesnt have it...
Would you really want 37" of 1360 x 768? :confused: I am not saying you will hate it or anything, you might love it. I just wanted to make sure you through that out. That is a fairly low res for PC use, particularly on that size screen.
I use 1280x1024 on a 19 inch.. would it be all stretched? and big? Is that the is 1300x 700 or w/e it is the max it can be?
Large panels like that typically have small resolutions for their size, what is know as the "dot pitch" which is basically the size of the pixels.
If you're looking for a large computer monitor and you want to keep a decent resolution at a large size the largest you'll get is 2560x1600 which are the 30" flavour.
Okay, thanks. Can you point out some good LCD 30-32 inch or as high as it gets with good resolutions?
Keep in mind i also want it to be my tv... sigh.. i wish the 37 inch could be 2600x1600 aswell...
