Deciding between case harnesses
I'm looking to purchase a case harness for a friend's birthday. I have been looking at the Sunbeam LAB-BA Black Lanparty Bag (LINK) and the GearGrip G2 PC Gamers Harness (LINK). The reviews have stated that the Sunbeam has a tendency to have the clips on the shoulder straps break. However, I have not seen many reviews that cover the GearGrip harness and was concerned that this may be a problem with that model as well. Does anyone have either of these and do you have any recommendations? FYI my friend has an Antec Sonata III case.
I've got a buddy with a geargrip and he likes it a lot, I used it once and it seemed really solid.
I have had a gear grip for years. not heavily used, but very handy when I do. good quality.
This is the one i have but as you can tell they are discontinued Harness link :mad: If you could find one i highly recomend it. I have 3 of them and the oldest one has lasted me 8 years and manny upon many lan parties.
The geargrip has a metal bar that keeps the straps spearated. The cheaper harnesses do not ussually have those.
I love my geargrip, I have had it for about 6years now and use it with mid towers to full towers with no issues.
