Deciding between a XSPC RX360 or a Swiftech Stackable Triple Rad
fx9
I'm looking to revamp my current water cooling rig by taking the radiators inside my case. I have enough room as its a Lian Li A77b full tower but I'm not sure which one would perform better. Between the XSPC RX360 Triple radiator or a Stacked Swiftech Triple Radiator setup. They both fit, its just a matter of performance at this point. So which one do you think I should get?
XSPC RX360 Triple Radiator
yhst-65556269779593_2083_31490468
Swiftech Triple Radiator Stackable
yhst-65556269779593_2085_54016120
the RX360 is a better choice if you want something better then the Swiftech radiators, but not overated like the TFC Xchanger 360 which is not that much better compared to the RX which is more cheaper too. I wen't with TFC since i couldn't get the RX :/ and i didn't mind spending a bit more (although it wasn't necessarily a good choice)
If you want bang for bucks, then the Swiftech radiator is better (not the stack version, although i heard it's ok as well).
There is a roundup article here if your interested.
http://www.skinneelabs.com
