D
Deleted member 96510
Guest
Being here on [H], you know I'm a tinkerer. I've got some parts to rebuild my rig that was having some issues. Now I'm trying to quantify the value of water vs air.
First here is the current config of the key parts:
Asus Rampage III Formula
Xeon 5650 w/ TRUE Black + NZXT FN120 blowing towards rear exhause
Asus R9 280X DirectCU II TOP 3 GB
NZXT Phantom (Front FN120 intake, Side 2x FN120 intake, Rear FN120 exhaust, Top FN200RB intake)
Parts also on hand:
GELID Icyvision Rev. A
Alphacool Nexxxos waterblock
Swiftech MCP655 with speed control
XSPC D5 Dual Bay Res
XSPC RS120 radiator
As it stands there are no issues ATM. I was intitially considering doing a CPU only loop because I have the parts, but then why not add a 240 or 360 rad and add the GPU? I would also need to buy a universal GPU block (not doing full covers anymore). Alternative is just save the money add another 200mm fan up top and maybe use the Icyvision if it will cool better than the DCuII cooler.
Water could be slick and probably allow me to overclock a little better, but I don't know if that will translate to tangible performance gains. I know the silence will be a plus. I just want some [H] input.
Parts also on hand:
XSPC RS120 radiator
