Tigerblade
- Jul 23, 2004
Gonna go GTX SLi. However, do you need the same 'brand' card's? E.g 2 x Asus or can you mix and match?
Nidhogg said:if you get the Asus TOP cards make sure you have room for them
That isn't the problem. It's the space between the PCI-E slots.Tigerblade said:Was looking at them but my local store is out of stock. Might go for the normal clocked Asus ones and stick some Artic Coolers Silencer jobba's on them I do have a Wavemaster case so room isn't a prob.
The Cobra said:Those BETA 81.84 drivers suck ass.
My HL2 frames went from avging around 85-90 FPS down to 35-40 FPS. I get the 90 FPS with all the eye candy turned on. UT2004 was the same way. Went from very smooth game play to just choppy.
I will stick with the 78.01 until something better comes along.
roflcopter said:That isn't the problem. It's the space between the PCI-E slots.
