AMDisSWEET
- Sep 6, 2002
I'm a n00b when it comes to OCing but I have read the well written guide on this forum about OCing a C2D/C2Q.
I'm currently Prime95 testing the setup and all is going well with the following:
E8400 (E0) @ 400FSB x 9.0 = 3.6 @ 1.2v (about 1.184 after droop according to CPU-Z)
1:1 Ratio 1600 FSB / RAM @ 2.1v per Corsair spec.
Stock Wolfdale 'mini' heatsink is keeping it under 57c under full load in P95. Room temp 75f.
Temps could be better if I put in the other 3 120mm fans the case was designed to house. But they seem to be within range.
On my first try I left CPU vCore on 'Auto' and it brought up the volts to about 1.36.
I noticed it within about two minutes and went back and changed it to 1.2. Did I mention I was a n00b? It's not likely that I damaged anything right? It's risky when you go above 1.45 from what I've read. I'm a bit paranoid when it comes to this.
I know this isn't an extreme OC or anything but I just want to boost game performance while still having a rock solid PC that will last 3-4 years or so with a GPU upgrade here and there.
Any suggestions would be appreciated.
