Decided on everything but mobo...
I've decided to go with a Pentium D 805 due to it's ability to be extremely OC'd and a Geforce 7600GT. It's worth it to me to pay $20 more now instead of waiting for conroe. I'm looking for a decent mobo that has at least one PCI-E x16 and dual channel support, but most of all one that will lend itself to overclocking the 805 to about 3.6ghz... any suggestions? The boards I'm looking at so far are:
Gigabyte GA-8I945P-G
http://www.newegg.com/Product/Product.asp?Item=N82E16813128294
Asus P5RD2-VM *preferred simply based on reviews... no dual channel support*
http://www.newegg.com/product/product.asp?item=N82E16813131590
I'm open to any suggestions, but I'd like to keep price under $120. (broke ass mofo)
Onboard sound/video is a plus because there will probably be a week or so gap between buying the CPU/mobo/RAM and buying the Geforce.
Almost ANY board that has OC options will let u do 3.6. Why? That is rough are which the 805D OC's to on stock V.
Do a lil more research or perhaps even wait a bit more for some sweet boards coming out that will support the 805D and even future Connies!!!
I've been working on the research front...
looking at ASUS P5LD2-VM now
http://www.newegg.com/Product/Product.asp?Item=N82E16813131545
I understand that almost any Mobo will allow for uppping the FSB to 180 (making proc 3.6) but I also want to keep it open to more overclocking in the future, and I'm still not sure how much the 945 NB will hinder it (out of the articles I've read, only Tom's mentions it). My other fear was pushing PCI clocks out of range, but because there's only a 133-180 it shouldn't happen. I don't plan on upgrading again for about two years, so conroe compatable mobo isn't necessary. As far as the mobo lending itself to Ocing, i'm not sure how much ram speed has to do with it.
well, i'm running a 805 on an asus P5ND2-Sli .. got it off newegg refurb'd for about $50, running 3.6ghz @ 1.425v, I've taken it up to 3.9ghz but I'll need a new ps to really push it beyond that. obviously my board may be a bit beyond what you need, as it's SLI, but I'm only using 1 pci slot and I'm *really* impressed with it. No stability issues or any issues whatsoever. The chipset is a nforce4-sli intel, so I have absolutely no idea if it will be compatible with conroe or anything beyond the prescott/smithfield/presler lines. This proc blows my old 3000+ venice away, so I have no need to upgrade any time soon. :)
note you'll definately want to get some better cooling (I'm using a arctic freezer 7 pro) before you overclock it beyond 3.0ghz, as that stock cooler just won't cut it!
good luck
definatelty doesn't have to be MATX, would prefer ATX actually. Needs to use DDR2 667 though, for financial reasons... I like the one you posted, but it uses 800. However...
http://www.newegg.com/Product/Product.asp?Item=N82E16813127216
This Abit uses 667, and is what I need 100%. Quick question... i thought RAM speed optimally should match bus speed (because of the drops of square waves needing to sync)? Should I worry about it supporting EM64T for future upgrades? Plan on running 2G max for at least half a year, and with paging that's 4.5gigs of page files. Not quite sure I understand the function of EM64T is why I ask.
This one is VERY nice for the price, but may be too good to be true:
http://www.newegg.com/Product/Product.asp?Item=N82E16813127226
It's socket 775 but isn't listed to support Pentium D... which i've read is only two prescotts back to back. I have a truepower 550W, and I plan on getting a decent cooler and using some arctic silver.
DONT GET ANY SLI on current MOBOS. IT WILL OC THE 805 but 4GET ANYTHING ELSE... AVOID!!!
If you are not in a hurry you should wait a bit more.... if possible. I know it's hard as I'm trying to wait but I cannot.
If you wait you can buy soemthing that will support conroe very soon. Should be within the next couple of weeks or so.
I'm going to build something temporary that I can passs on to the woman so I'm okay.
how much does having dual channel support help out actual speed? I'm running an UATA HDD to start off, and I have a feeling that will be my biggest bottleneck :(
How about a Abit AW8. I been recommending this board to alot of people who are looking for a good Intel board. Its only 84 dollars now, based on the 955X chipset, so far does a pretty good job at overclocking. Im stuck at 250FSB right now(stock voltages also) because my loads are in the 70 with a stock heatsink and waiting to get the Scythe Ninja when Im come back from vacation. Many features. Also has DDR2533/667/800 ram support. Also has Dual Channel support. Alot of people though say the DDR2800 support is really picky on what ram you get for it. But you are getting 667 anyway so it wont matter. Very stable from my experiences. To me its the best value right now on the Intel side as long you dont want Crossfire or SLI. Then again I own one and may show some biased towards it.
Sights on AW8 or NI8-SLI bu Abit. NI8 has sli support for future, but AW8 is based on 955... any suggestions?
Meh from what I heard the SLI Intel chipset is buggy, unstable and you are almost taking a chance of getting your ram to work for it. I almost brought the Asus and did some final research on it by going to the Asus forums and like every 1 person out of 5 has a perfect one.... Im guessing the same can probably be applied the any other brands out there. The chipset was designed specifically for AMD's, so it should be a surprise how hard it probably was to get it to work on Intel systems.
