Decent Overclock for my 4400+ System
USMC2Hard4U
Well I know I can go higher but this is what I wanted (Because I want to keep tight timings)
I just bought an Athlon X2 4400+
DFI Lan Party SLI -D
2x1GB DDR400 OCZ Platnium
etc etc
I got 2.4Ghz Per core out of my Athlon X2 - XP120 HSF with Panaflow M1A 39C Idle / 44C Load (both cores)
218 x 11
218x5 HTT = 1090
and my ram is running 1:1 at extremly tight timings for it being only DDR400.
Im running it at 2.9Volts Cas 2, 3, 2, 1T and everything else is tight too. My everest latency is 50.1ns... im 3rd from the top... seems good to me. I know I can go higher with a diveder or something but this is good. Just wanted to let you all know.
This ram is better than I thought, and the XP120 is super quiet and rocks
good work usmc. Looks like a good OC on the memory and cores.
