Decent Mid-range board?
Thermo1223
I haven't been in the loop for a while so I like to get rid of this Dell I recently acquired and build up a semi-decent system.
Requirements:
Well I always have been an Intel whore unless AMD's are really that much better I could go that way as well. Doesn't matter to me.
Some Overcloking ability but it doesn't have to be hardcore, but I do intend to overclock and experiment with certain things. Basically a best bang for your buck but not really sacrificing anything.
Going to need Sata as well.
I was also an Abit & Asus whore as well but I'm pretty sure everyone is great now.
The last time I did this was 2-3 years ago so man things have changed.
Thanks
the DFI ultra-d AMD socket 939 sounds like the best for you. It can overclock and is very solid, only problem is that it probably has the highest cost of the mid-range boards.
Epox 9NDA3+ if youre going 939, just as stable as the DFI at high overclocks, but without the insane voltage options (that you dont need unless you have ch-5/bh-5 or such like).
Or if youre going Intel id wait for Nforce 4 Intel edition, at least to see what it brings to the table.
As far as which to choose, well, for games A64 = teh win, but if its mainly for office/photoshop/whatever then id say go with one of the Hyper threaded P4s.
