Decent amd64 water block?
Morphes
Hey i am looking for a good waterblock for amd64, nothing crazy fancy but decent little overclock. I am getting a 2800+ on an abit kv8 (one with fan on the back), would my current system be good enough? 2 120mm fan rad with 2 fans on it, about a 120gph pump. on my current setup it doesnt go over room temp.
thanks
EDIT
Cheaper the better
About the cheapest god water block would be the Swiftech 6002. You're pump is a little weak IMHO, but hey, you have to use what you can aford. A danger Den D4 12v pump would be alot better, but costs alot.
For the price the Maze4 works excellent and the Hydor L25 or L30 is nice too...heck the Maze4 is really a great block and works well with lower volume pumps. Handles my system quite effectively and very quiet. See the sig.
i like my swiffy 6002, works great and easy to install to boot. no need to remove the metal backing plate since it usually a pita to remove
oops my bad i have a L25 hydor pump (185gph) thanks for the help
