Decent 22" Widescreen with thin bezel?
Unknown-One
I've been looking around for some decent 22" widescreen monitors with thin bezels to go into a triple-monitor configuration. Going for as little gap between the panels as possible.
Looking to spend around $200 per-monitor, currently have my sights set on
Product.aspx
, but I'm not sure how good a panel it is.
I bought the Acer X223WBD for someone because of the price. It is actually a lot thinner than I thought it would be.
I purchased the Asus VW222U last month and I love it. The VW224U is the exact same monitor.The VW222U is a discontinued model and this one replaces it. The only difference is that the 222 has 16.2m colors and the 224 has 16.7m. I read an article that reviewd several 22" monitors and the 222 won the award for the best among the group. The Samsung would've won but it was in the $300 range. It's a "true" 2ms response monitor(actually a record breaker), according to their findings. The bezel is roughly 5/8".
In my opinion you can't go wrong with the Asus, and at that price,it's a steal.
Heh, go figure, guess I should have gone with my first choice all along :p
VW224U it is! Ordering now.
