server_error
- Jun 8, 2004
Well, as I posted before, Swifty's MCW50-T, which is advertised to fit the entire 9000 series, does not fit my 9600 Pro. Well, after a couple emails to their support, they stated that "No ideas without specific information. From your explanations, it seems that this board is a non-standard retention system." Well, he was asking for it..... I measured out and drew to scale an exact diagram of my card with full measurements [
]. Then tonight I got some pics too.... Here's the later part of the mails I sent in:
"This board uses the standard ATI mounting setup, but it is slightly lower. This is a characteristic of ALL 9600 boards, at least from the data I've gathered. This is the system used by ATI on their boards, with which you claim compatibility. I'm not sure exactly what kind of specific information you want, but I would assume that as a manufacturer of cooling solutions you would have hardware samples of the video cards you intend your block to cool, or at the very least technical diagrams. However, if that if not the case, I have made a 1:1 scale drawing which reflects the measurements of my 9600 Pro. I have no formal training in drawing technical diagrams, but I believe that this accurately shows the dimensions of my video card.
I have put a great deal of trust in Swiftech; every part of my watercooling system has come from your company. However, if basic issues such as the ability of a waterblock to fit the card that it is advertised to fit cannot be resolved, I will be going with a more reliable company in the future, and advising others to do the same.
Your customer,
[me] "
Here's the diagram:
Then later on, after not getting a reply today, and getting some pics:
"I've gotten a digital camera and taken a few pics. Forgive me, they're a bit blurry, this was using a borrowed camera which was not really intended for close ups. The first pic is from the top just to show that it is mounted correctly. The second shows how the neoprene just barely goes over the AGP connects, enough that I cannot get it to fit in the slot. The third demonstrates the same point, except from a side view. I'm tempted to cut the neoprene a little and make it fit, but this would probably increase the chance of condensation, and also void my warranty.
A timely response would be much appreciated, because as of now my main system is drained out and waiting for the addition of the gpu block, and I'm stuck using an old computer. It is too much of a pain to fill and drain with the Fill/bleed kit you guys make for me to want to do it any more than I absolutely have to.
Your customer,
[me]"
Pic 1:
Pic 2:
Pic 3:
Hopefully I'll get a usefull reply tomorrow.... if not, then I will try to contact Bill Adams through a PM at Procooling (I read a lot there, but don't post... I'm not knowledgable enough on most matters to say anything that would be of value to the pros over there).
Your customer,
[me] "
Here's the diagram:
Your customer,
[me]"
Pic 1:
Pic 2:
Pic 3:
