Dead Video Card? Pictures...
A couple of those pictures look an aweful lot like what I am experiencing. I'm still waiting for the hive to help me out as well...because at this point I am ready to cook it lol...But with your problem, you are actually able to see text and windows, and it clearly shows there is a problem in device manager. I would assume that it is the card itself failing on some level. but it wouldn't hurt to wipe your drivers and do a fresh install (if you are able to) to be sure they didn't go bad.
Drivers are fine.. I have an identical card working perfect. Just this one is toast. I'm thinking about putting it in the oven
I guess it's a little too late since you baked it, but is the card still under warranty?
Also, this looks like a memory problem, since the card functions fine aside from the display artifacts. If this is a factory-overclocked model (or overclocked by you), could you try clocking the memory and core back to stock (or try an even slower clock speed than stock)?
Card is on a waterblock and stock settings 192 model.
If it is a memory problem I could check it out those modules and look for any thermal paste that might be bridging connections...
