Dead USB ports on Lanbox
TWO515TY
So today, I got a new Seagate 750GB drive for $100.:D Great deal right?
So I'm copying stuff from my 200GB HDD to my 750GB and I plug some headphones into the front panel headphone port. At this point, my monitor goes blank and my computer is unresponsive. I restart my computer and I noticed that my mouse, plugged into the front USB port, no longer works.
Plugged in another mouse and a thumb drive and not one of them works on either USB port. The front panel audio still works just fine, but I can't use my USB devices.
Anyone have any suggestions? Is it possible to buy a replacement front panel for my Lanbox?
EDIT: Ok, so it was the headers on my mobo that got killed (better my cheap ECS mobo than my expensive Lanbox case I guess). Plugged the USB ports into different headers and they work now...
PHew*:D ibought a lanbox, it wouldnt be nice reading about a faulty box :p at least its fixed now, grats.
Sure you didn’t plug it in wrong? Been there, done that. Fried components in the process. They should key the plug so you are not able to plug it in incorrectly, but sometimes they come with several separate wires with some assembly required.
The USB headers are keyed. In fact, most of them are nowadays, minus the ones that come as SEPARATE FRIGGIN PINS.
Gits.
In other news, why the ECS mobo? Some deal from Fry's? (Why don't we get Fry's up here in the North? Black Friday/Boxing Day sucked. Royally.)
Yea I know I didn't plug it in wrong because those USB ports had been working the entire time I had this case! I was just so shocked when something like plugging in headphones fried my ports. Maybe I had somehow built up lots of static and caused a short on the board (Which might explain my the monitor turned off), but this never happened before.
Why the ECS mobo? Because I'm too cheap and lazy to upgrade. Well actually, I have the money right now, but the main reason I haven't upgraded is because I want to see if the Gigabyte G35M-DS2R is going to be better than the Asus P5E-VM HDMI. I don't want to order the Asus, put it in and all that, then find out the Gigabyte board would have been better for me.
And yes, I did get it in a Fry's combo a loooong time ago. My old Asus P5AD2-E (that board was the shit!) died and I needed a replacement. I had gotten a service warranty from Fry's on my mobo and proc, but the lady that did the warranty did it for $300-$400, when it should have been $400-$500, so I had $200 to spend on a mobo. I was rocking a single core Pentium 4 and being unable to find an affordable motherboard that had EVERYTHING I wanted (and being without a computer for a week :-\ ), I settled for the Pentium D 945 and a cheap ECS mobo for $180 (which was a decent deal back in the day). I figured since I didn't overclock much and I was getting a dual core I'd be ok. So far, the board's been ok for my uses, except for only having 2 DIMM's. I have 3GB of memory lying around that I can't put into this board.
Sorry for writing a novel, but yea, that's why I'm rolling on that garbage ECS... But once I get a new mobo (which'll be whenever Gigabyte finally releases their G35 board), this ECS board is going into a Microfly with a bunch of other random parts and is probably going to be used as a HTPC or NAS.
