wayout2day
- Oct 15, 2006
I repaired a PC to good working order recently. I added a second HD, and brought it from Win ME to Win XP pro.
However, the owner's friend borrowed it and used it to test out his components (having killed his own PC). Sure enough, the owner brought the machine back when it wouldn't boot up.
This PC has a switch on the power supply and on the front. He had disconnected the front switch, and had done who knows what else.
The PC would not boot up and instead gave the missing file message for basic XP files. It further suggested that the original CD be inserted to find the files. Of course, the machine came to me without these. I installed a legal copy of WIN98 and then a legal upgrade copy of XP Pro.
After checking the HD in a good PC and finding it ok, I checked the cables and found them in working order. The CD drives and the 3 1/2" drive all checked out. I set the boot order in setup. This worked ok.
The PC will not recognize any device...CD, Diskette, HD.
Motherboard GA 7Z M
Athlon Socket A processor
128 MB RAM PC-133
The quantum hard drive 15.0 GB--Fireball LCT 15
Hitachi HD 40 GB Deskstar 7200 rpm
Mitsumi 3 1/2" diskette drive
Lite-On I.T. Corp CD-ROM Drive Model LTN-525
Phillips CD drive Model # PCRW2412
I have disconnected and reconnected and tested. The cables are all right, the power leads ok, the parts are installed ok.
Any suggestions ? I don' know if the guy shorted out something. Shouldn't the PC at least boot into a boot disk in the diskette drive ?
Any help welcomed. I am trying now to glue my hair back onto the scalp...
Motherboard GA 7Z M
128 MB RAM PC-133
