Dead motherboard?
vortec4800
So I got a new motherboard the other day, and its got onboard everything. I plug the ATX connector into the board and turn on the PSU, and the lights on the onboard NIC card are up and running so it is getting power. When I push the power button on the case, nothing happens at all. I've checked and double checked the location of the little connector for the power button on the case and I know its correct. Why won't it switch on? Any ideas? Is the motherbaord just bad?
There is two connectors you should connect to mobo. Have you done that?
No, no, and no. There is only one connector because this is my other computer, I can't seat the CPU because its a via board, and I'm just retarded because I found the problem to be the CMOS jumper in the clear position.
Oops.
