Dead Motherboard?
arrgon
I'm not sure where to put this, so please move it if this is the wrong spot. I've been working on a computer, which went bad. The processor is toast, the power supply is probably bad, I'm not willing to test it in another computer, and I think the motherboard is bad. The only other option is that the motherboard is fine and the memory is bad but I have no way to test this, which brings me to my question. If all the parts in a computer are bad and I hit the power button, the cpu fan or the hd fan should at least spin up, right? If nothing spins up I assume that means the motherboard is bad.
If you had another good quality power supply to put in the dud system that would be a start. One that has overload and short circuit protection so it won't be damaged if there is a short.
Already tested it with a new psu and processor from a working system, tried the processor from the broken system in the working system which is how I know it is toast. I don't know what happened to the system, person didn't want it anymore, all the drives in it are just fine, rest seems destroyed.
