Dead Motherboard? Symptoms?
osx3ntropy
Sorry, this is the first time something like this has happened to me. I'm pretty sure the motherboard has gone out, but I'm not entirely sure. I'll just list of what happened.
Specs
AMD Athlon64 3000+ 754 pin, overlocked to 2.4 ghz, RAM timings are set (one notch below 9/10, can't remember)
Antec P160 case
1 - suddenly machine loses all USB recognition. this is shortly after I plug my JVC Everio camcorder into a front case USB port
2 - Windows tries to install generic HID device, machine completely shuts down shortly afterwards.
3 - machine will not start from ATX switch or onboard switch, indicator LED near bottom of PCI sockets is still on, indicating at least that part of it is still getting power
I'm stripping it down ATM, I will not be able to sleep until I come to some sort of absolution :S CPU temp had a limitter at 60C, normally was in the 47 - 52 range with stock cooling, even during gaming
I'd say check the USB connections on the motherboard, try the camera on a different computer as well.
Full system specs would be helpful as well.
AMD Athlon64 (overclock settings as previously noted)
DFI LanParty UT nF3 250gb
Corsair XMSPRO PC-3200 / DDR-400
350W Turbolink PSU
PNY Verto GeForceFX 5900SE
Hauppage WinTV PCI Card
Maxtor 80gb 7200 RPM HDD
Samsung Writemaster DVD-RW
Also, I'd like to add that the motherboard's DRAM Power LED is no longing coming on.
350W Turbolink PSU
The DRAM Power LED not coming on (i assume you have the ATX PSU switched to power the mobo..) is not a good sign! (lol) I would first check your connections from the motherboard to the front usb ports and make sure you don't have them incorrectly wired..
As long as you can rule out the PSU (do the paperclip trick if nothing else), then if you're DRAM light isn't coming on.. I'd also say you're mobo's gone.
If all the power connections are fitted properly, then I'd venture a guess at the PSU being the problem, I've heard turbolink is a pretty cheapo brand, from your system specs it doesn't look like it would be the problem, but I'm not exactly familiar with the power requirements on the FX series of cards. I guess just start a general troubleshoot, strip it down to nothing but what is required to POST which I believe is just Vidcard, CPU, RAM and try power up. Anyway I hope this was somewhat helpful.
Currently I have may motherboard its tray on the desk, with the CPU, RAM, PSU, and video card plugged in. At the moment all I'm trying to do is make the CPU fan turn or at the very least evoke a few beeps from the PC speaker. LED1, below PCI5 is on, the DRAM power LED is still off. And yes, my switching power supply is switched on :p
Thank you all for the quick, helpful support by the way.
Even if the rig won't post the fans should at least spin up, sounds like the PSU to me. How are the fans powerd, 4 pin molex from PSU or via the motherboard headers?
There is one straight from molex, this is suspicious indeed. I'll go ahead and hook one up to my barebones setup when I hook up the one I'm currently cannibalizing from another project machine. The PSU's fans aren't turning on or anything when I pretty the switch, the only real indicator of any power I actually have is the little LED in the PCI bracket.
After hooking up the scavenged PSU (which was working before I unhooked it), I started it up. Still nothing, except for a small nuance. When I pressed the onboard power switch, the DRAM LED and the two of the XMS indicators blinked for less than half a second, but I was back to page one after that - PCI LED on, power supply fan or PSU fan isn't turning on. I'm going to neglect to hook up the 120mm molex fan I have unless it's absolutely necessary, because I don't want to waste those rubber gromets that came with the case :)
I forgot to mention my RAM in the specs, btw, its Corsair XMSPRO PC-3200 / DDR-400
I was getting all excited that it could be the PSU too, as these damn mobo's are still $110 on newegg even though they're like two years old.
Camcorder is self-powered, was plugged into charger when it happened. Also, same results with different PSU as noted above :S
Oh4Sh0 said:
do the damn paperclip trick on your psu!
Which pins again? I'll do it tommorow :)
I can rest better now, having a bit of an idea of WTF is going on.. I have to get up for school in less than 6 hours, and then I shall cope with having to drop more money on outdated hardware (cant afford 939 pin + PCI-Express video card + mobo atm :S)
Hmmm maybe I'll get a barebones shuttle...
Anyways, thanks for all the help everyone.
Changed out the PSU and it still didn't work. I guess that points at the Mobo. Check all the jumpers, if you haven't already clear the CMOS, thats kind of a shot in the dark, but it can't hurt.
CMOS has already been tried, machine hasnt been jostled to cause any jumpers to loosen for a long time..bleh.
It's only $100 more for a Shuttle SN85G4V3 than the NF3 250gb, small price to pay for the form factor.. on another note, can I hook up my harddrive to another machine as a slave to recover any data I may need?
As far as I know that should work just fine. My system's mobo, a s754 ASUS, kicked the bucket about a month ago, PSU problems, heh. So I took the opportunity to upgrade :p.
your mainboard has taken the dirt nap. you shorted it somehow when you plugged in the usb camera. swap out that camera's usb cable before you try it again. i mean when you try it to see if your camera is fried also. do not plug that camera into any mainboard with that cable, unless, of course it and the mainboard are of the disposable variety. as for your 250gb, i dont know how old it is, but dfi customer service is only slightly better than an 18 inch nail thru your balls. attempt the rma, while your waiting the 2 months for it to come back, buy an epox.
good luck.
Found that one out today.
I ordered the Shuttle XPC SN85G4V3 off Newegg, hopefull it'll be processed and shipped by Saturday. As far as the camera USB cable, it's of the generic variety - my PSP usb cable has the same type plug, so I won't hesitate to use it instead. Camera is still good.
