Dead mobo?
Nicolaskl
I'm making my old PC into an HTPC, put it all together last night. The only new hardware is a new HD and a new mobo, everything else is from my previous PC which hasn't been used for 2 months because I moved but was working fine then.
Fired it up this morning. POSTed fine a couple times and got to the point where it looked for an OS. Popped in a Vista 32 OEM, it POSTed and started loading the OS. Got to the point where it pulls up the first Windows screen (blue Vista background I guess) and then hung up. I reset it and
Crap, I may have just figured out the problem. My case has the reset button recessed and when I first got the case it would get caught behind there and stuck in the depressed position.
Anyone know if that'd do it? Right now it powers up but nothing happens, no POST, no beeps, nothing output on the display. That's gotta be it, right? You don't need a reset button hooked up right? I can just pull the header? Because the button itself is buried underneath optical drives and hard drives and the LCD PCB, I probably don't wanna hassle with for as little as it gets used.
Edit: Problem solved, it was the reset switch.
