Dead Mobo? (IC7-g)
bluesdoggy
First my system specs that are relevant:
IC7-g , latest bios
P4 3.0ghz Northwood
2 512mb Corsair XMS Dimms
Geforce (PNY) 6800 Ultra
Antec NeoPower 480 PSu
Computer has been running fine for ages now. I shut down after a long session o World of Warcraft to remove an Sata drive from the system. Removed the drive with no problems. Durin removal system was powered down, unplugged, psu was discharged and i was wearing a static strap. Additionally the removal took place on a tile floor. Upon rebooting my machine, the system locks at the POST screen right after Proc ID and before completing the memory test line. To be precise it locks after outputting "Memory Tes".
I've tried the following:
Removed alll drives and pci cards from system.
Reset Cmos, removed Cmos battery, replaced Cmos battery.
tried alternate memory, tried 1 stick of known good memory in every slot of mobo.
removed PSU and tried alternate model
Removed videocard and tried alternate.
Alllowed system to sit unplugged for approximately 30 minutes and then tried all tests again.
Without fail, the same error occurs during all tests. One variance is that the text displayed to the screen is different when trying different video cards.
With the 6800 ultra, lock occurs at text:
"memory tes"
with ati 8500 lock occurs after that line has completed being dumped to screen.
I would assume this has to do with the way the different video cards output their buffer to the monitor.
I have isnpected the mobo closely for leaking/swollen capacitors and found none.
At this point i'm not sure what the problem could be aside from the mother board going bad. Even then, i find it odd the mobo would just suddently crap out.
Any suggestions would be greatly appreciated.
I've had a problem with an IC7-G too where I made a change to hardware and then it wouldn't boot after. Luckily I had a spare motherboard, but no idea why it died.
Turns out...and this is great...... this is just fucking fantastic..
My WONDERFUL, MATURE, HIGHLY BIOS REVISED motherboard, will not boot, infact, ALWAYS HANGS at "mem tes" when a usb HD is attached to it when booting.
CAN YOU BELIEVE THIS CRAP?
I think i'm so mad because i just had to cancel my order for a 3500+ winchester with an MSI neo2 mobo.
:( my computer works again... yay :(
yep, my IC7 one day just didn't wake up after being put to bed... RIP IC7! :D I mean I just turned it off but the next day it just didn't boot, I had to replace it eventually :rolleyes: I think it's my last Abit mobo ;) :p
had a similar problem with an ABIT ai7
Hung in windows one day and never turned on again :(
Yeah..abit mobos seem to have a bad reputation for not wanting to boot after opening it up. That's one of the reasons I've always had a really really cluttered case. Everytime I opened the sucker up to clean the cables, the mobo decides it doesn't want to boot. Spend three hours cleaning cabling, and end up screwing it all up cause I have to recheck connections and redo everything just to get the freaking thing to work again. Every single time I open the thing up, even if it's just to swap dimms for the RAM, it stops working and I have to practically disassemble it to get it working again. -_-
