Dead in the water
malebolgia
I recently received my processor earlier this week, but of course I ran into problems during assembly today. After getting everything hooked up it seemed to be working just fine. Later I changed a few BIOS settings (time & date), and then rebooted the machine.
After the reboot I received a voice message from the computer telling me "There may be a problem with your CPU". The PC was only on for a few minutes, and during that time I was able to see that my processor was running around 44C (around 100F). Now when I start my computer all I get is that voice message "There may be a problem with your CPU", that's it the computer doesn't even get to the BIOS screen. So I'm stuck at this point.
I guess the problem might be heat related, but I have a really good CPU cooler and thermal paste. Anyway below is a list of the equipment that I'm using.
Non Working System Specs:
Edit: It completely slipped my mind, but I remembered that there's a motherboard update I need to apply. This is the e-mail I received:
Thank you very much for contacting Albatron technical support,
We support this model CPU, but you have to update the BIOS first(Please see the
attachment)
If you have any questions for our products, please feel free to contact us.
Problem is I'm not sure if I can apply the update now. Seeing how I don't have access to a lower end Athlon 64 model to get to the BIOS. :(
DOH!
malebolgia said:
How do they expect me to upgrade the motherboard if I don't have a CPU to run it?
Honestly, looks like you probably got an original board thats been on the shelf awhile. They update the ones they ship out generally so that this isn't a problem. I'm afraid you are gonna have to find a buddy with a low enough proc or maybe even go into a computer repair shop and ask them to do it for you for a cheap price.
How about DLing it from another PC then and then flash the new BIOS on your board?
I made assumptions. If you were able to barely boot for awhile before, try resetting your BIOS and then flash it after getting the download from somewhere else as already posted. I thought you couldn't even get the machine to POST.
Well, you said that it let you get to the bios once before you changed settings (on the first boot).
Maybe you should try to Clear the CMOS (be sure to unplug the power supply as well) and let it sit in clear mode for at least 5 minutes.
Then, set the jumper back, plug in the PSU and try to boot again.. BUT have the dos floppy and bios update ready so you can go right in and update the bios.
Biggest thing is to make sure the bios is COMPLETLEY cleared and you may/should be able to get it to work.
I did a simmilar deal on an older motherboard, I just had to make sure the CMOS was totally cleared out before it would work.
Hope this helps or that you find someone with a proc you can borrow.
D.
D.
Thanks guys, I'll try that when I get home (few hours from now). In the mean time I'll download the update to a floppy disk, I hope this works :D
Format it first, and use two. Invariably when you really need something and you brought it from somewhere on a floppy, the floppy will have gone bad in transit. :)
Sorry for asking such an easy question, but I'm not running on a lot of sleep right now.
How do I make a bootable diskette? I already downloaded the two files needed. I'm not sure I did it right, so if someone could go over my steps I'd appreciate it.
Steps I took:
  • Choose the option "Create an MS-DOS startup disk"
  • Copied the two files needed to update my motherboard
You created the dos startup disk ok.
I prefer to create a Dr. Dos with no utilities disk ( www.bootdisk.com ), then on a seperate disk copy the flash utility and bios image.
SO, you boot off the Dr. Dos disk, then insert the other floppy with the flash program and bios image then follow the flashing directions.
Hope this helps
D.
Alright guys that BIOS update did the trick. I was able to boot correctly and install XP last night! I have one more question for you guys; I left my computer running in the BIOS for about 15 minutes. During that time my CPU temperature was around 44C to 46C (open case), is this a safe temperature for an Athlon 64 3700+? Of course this is when the PC is idle; I haven't yet had a chance to record the temperature after running a game or Windows for a large amount of time.
Your temps are within the thermal limits.
I would just do some benchmarks (Prime95) once windows is up and going and keep an eye on your temps.
You should be fine though.
D.
D.
Do you know of any good temperature reporting software I can use?
Motherboard monitor http://mbm.livewiredev.com/. Its no longer going to be updated, but our board is still in their with specific support. I perfer it to the MSI core center. Just runs in the tray and reports temps that Sisoft agrees with.
Thanks, I would like to note that I checked my processor temperature yesterday (after I shutdown my computer for the day). It was around 52C, now that seems to be too hot for comfort. I'm kind of puzzled by this because I have a pretty good cooling system. I have two intake fans and one outtake fan towards the back of the case. I’m starting to think I put the thermal paste on wrong.
For whatever reason the day I applied the thermal paste I didn’t start up the computer. Instead I simply securely attached the heat sink/fan and said to myself “That’s it for today, I’ll startup the computer tomorrow.” That may be the reason right there I’m not really sure. Anyway below is the list of the case and thermal paste I’m using.
Components:
