Dead IDE channels?
shadowbreaker513
I have a MSI K8MM-ILSR motherboard that I just got yesterday. I was installing it today and everything went for the most part pretty smoothly. It boots up fine except no matter what I do, it will not detect anything on the primary or secondary IDE channels. I've tried 2 cables, 2 hard drives, 1 CD-RW drive, and every jumper setting on my main hdd. It keeps saying no disk detected. It will pick up a floppy drive though. Is there something easy I am missing, or is my mobo defective? Could I pick up an IDE > SATA adapter and run my hdd on that until I get this figured out? Also, I got a feeling this may be associated with something that happened during assemly. I stood up and accidently shocked the cd drive while everything was plugged in (into the psu, mobo , and wall). It seemed dead at first, but I let everything sit for about 15 minutes, and it worked (seemingly) fine again. Could this be the cause?
Also, does anybody know if I can use a spare PCI IDE controller card I have without a driver disc?
