Dead CPU/Mobo/Video Card/......
shadowbreaker513
This is related to the problems I had before but since the computer finally died, I think it was needed to start a new topic.
Problems before:
Video output crap-outs whenever the moniter cable was moved (probably not related)
Frequent crashes in WoW whenever I used a UI mod in the capital city
WoW crashes where all the colors on the screen would smear and get horribly corrupted, background music would keep going.
WoW crashes where all the colors on the screen would smear and get horribly corrupted, rest of the computer would lock up.
Random black polygons pulled out into some far away location on certain characters from certain angles (happened the night it almost died from heat, and last night before it died for good)
Hard lockups on the desktop
Hard drive clicked (only once, not terribly concerned about it)
CD drives are hit or miss, work some days fine, work other days sporadically, work other days not at all.
Problems now:
Horrendously corrupt images when I bring it up, think picasso spraypaint colors, which then moves to what looks like a zoomed in image of a TV screen with red/green/blue rectangles everywhere.
Brings up the first mobo screen in the boot process and hangs there
Right now I'm thinking CPU as most likely culprit, followed by video card, motherboard, and then some PSU problems backing the real one up. Anybody have any ideas? Nothing was overclocked, for the past 3 weeks temps have been fine and under control. Before that it was in a SFF, and the thermal paste on the cpu somehow managed to evaporate (only way I know how to explain it) and temps shot up to 85C load, and it was about a day before I noticed it running that hot.
I'd start from trying different vid card.. as for the CPU - clean the HSF, it won't hurt to put some new thermal paste either..
Have you tried the video card in another computer, same with cpu? that could tell you alot about your problem. Sounds like you have a cpu and video problem possibly ram related too. Best thing is to try the components in another good working computer and go from there.
This morning as a last futile effort, I unplugged the IDE cable on the 2 CD drives, swapped out the RAM one last time, and removed 2 screws that had fallen to the bottom of the case. Tada! Working fine so far. I got a feeling the second stick of RAM was corrupting EVERYTHING. Now I just need to buy a new stick, 512mb runs like crap.
