Dead choke ferrite on mobo?
Piotrsama
Hello guys.
One of my systems is having serious stability problems. (all components running at stock)
It can't finish loading Windows 7 without resetting (I also tried a boot CD with Ubuntu, same problem).
I tried all kind of things to get it running:
Used only one stick of memory, taking out the PCI-E VGA and using onboard video, no HDs connected (loading Ubuntu from DVD), almost everything but couldn't find a faulty component.
Only things I had left to blame are PSU, CPU or mobo. (I don't have extras for that system)
A bit frustrated, I started watching the mobo closely, and I found 2 capacitors that seem a bit inflated on the upper side, and they are considerably hotter than the rest of the mobo's capacitors.
But the worst problem seems to be what I think is called "choke ferrite".
The whole mobo: (MSI K9A2VM-F V2)
The "problematic" choke ferrite?:
In my mobo it's not green (it has a color in between violet/pink). And two of the capacitors next to it are a bit swollen and way hotter than the rest on the mobo.
Also, the metal that surrounds it is black, as if it was burned.
I checked on the internet for photos of this mobo (like the one I posted), and they all have 3 green "chokes", while mine has 2 greens and one violet/pink.
I think that's the problem.
Strange thing is, this morning I let it do some memtest, and after 5 hours, no errors, and the machine was still running.
But if I try to load a graphical OS, it just resets.
What do you guys think? Time for a new AM2+ mobo? :D
Thanks.
