Dead Card? Probably... HDTV tuner?
Weiser_Cain
Ok I have an old computer with an Alllinwonder 8500dv or something I used just for TV and backup storage. A day or so ago I noticed I couldn't reach it on the network; I flicked over to find the 'TV' bit still working but the computer otherwise wholly unresponsive, to the point that the keyboard was dark.
I hit the reset button and it started up normally. But now it seems to die at random going unresponsive this time with a garbled screen. I tried not running the TV app and it still died on me.
My guess is that the video card is fried. Thing is if I replace it I still want to watch the TV. HDTV reception would be really nice as comcast has given me a few HD channels that I currently can't look at I don't however have or want windows XP, I use win2k and I wonder (as I did a while back) if there are good solutions for watching HDTV on compys running win2k?
Also note that I may abandon my old box and in that case I wonder if it'd be to my advantage to have a separate tuner card so that I can also have really nice video card?
Problem is cable HDTV is encoded and there are no PC HDTV tuners that will decode cables signals. (I was thinking of it myself)
You can still get over the air HDTV using currently available PC tuners that work with an aerial/antenna. ATI probably has the best HDTV tuner for the PC...but the channel selection is relatively minimal right now.
I'm not worried about decoding straight from the box as I doubt you could get all the special features of the box working. I just want to be able to watch output from the box on my computer.
By the way I'm convinced it's the gpu as I turned the resolution down from 2048x to 800x and it's been running for hours without a problem.
The ATI HDTVwonder is capable of decoding cable/cable-HDTV. There is however no SOFTWARE available to do it.
Someday the cable systems will key into the HTPC craze and make a "cable card" box available in cooperation with tuner makers, so your own settop box can function like the cable company box does now.
Technically nothing but software stops us now, but its a big hurdle to overcome the encryption, plus the legal issues. So far noone has pulled a DvdDecrypter equivalent.
But to me, if you are paying for cable, you should have the option available to you to rent/buy a cablecard attachment, have them supply the "card" to you and let you use your own hardware from there.
Then making a supertivo with 3 HDTVwonders, MediaCenter, bluray/w-ever DVD, and huge disk arrays would be a snap.
There are times when I really wish the comcast dvr had THREE tuners in it, rather than 2.
But the industry is still in the darkages, just like the US cell phone industry is also in the dark ages. There is no vision, insight or hope for improvement in the near term.
I use win2k; the hdtvwonder card requires XP, yuck. My computer is now fully dead, it won't even start now. Just gives an ugly beep then sits there with a blank screen and hard drive light on. fun fun
At this point I'd be ok with your video capture card recommendations... I'm thinking of getting an nvidia card and it could use a partner...
