Dead Asus A8N?
Chris431
This morning I turned my computer on to find that it would turn on for about 10 seconds before turning back off. Notably, the 3-pin high speed 120mm fan that is hooked up to the motherboard would only rev up to about 1/3 to 1/2 the normal bootup speed (once in the OS, speedfan kicks in and spins it down....thus I'm familiar with its sound when at full speed (very loud) versus slower speed (near silent)). The motherboard is an Asus A8N-SLI Deluxe. The internal green "power" light on the motherboard lights up. I've had it for about 1 year and 1 month. I have done all the trouble shooting I can think of including:
(1) Unplugged devices mostly 1 at a time to make sure it wasn't a PSU issue.
(2)Plugged in a different (& sufficient....it was previously driving this PC) PSU - same results
(3) Used the primary PSU to make sure that unplugged from the motherboard it had no problems driving the other devices (hard drives, fans, etc.)
I did not try swapping out the CPU since I do not have another Socket 939 chip. Also, the nature of the problem would seem to me to be independent of the CPU.
I have concluded that there is some power distribution problem within the motherboard that is causing the problems. This not only accounts for the 5-10 seconds it remains powered up but also the fact that the fan plugged into the motherboard only spins at 1/3 to 1/2 speed during this time.
I've scoured this and other forums and did apply some of the suggestions elsewhere (ie. unplug the Power LED cable as some have experienced that could cause shorting like behavior) but have been unable to resolve the problem. I figured I'd post looking for ideas/confirmation before Monday rolls around & I call Asus for the likely RMA (yippee....couldn't have happened at a worse time....thankfully I have spare PCs).
Thanks for any suggestions.
Chris
Make sure the CPU fan is powering up.
If not it can power the board off depending on CMOS settings.
Try using each stick of ram in different slots.
Try a different graphics card.
That and the CPU are the main high power devices.
A fault is more likely on the graphics card so its worth trying another.
Check the voltage of the CMOS battery.
If it is less than the rated voltage, it can cause odd behaviour.
I am having the issues with this same motherboard except instead of the computer shutting off, I just get a black screen. I've checked just about every other component (excluding the CPU since I don't have a spare as well). I even RMA'ed my video card since I suspected the video card over the motherboard since I was getting no input response from the monitor, but it turns out that wasn't the problem (I had a brand new replacement video card sent). I suspect it is the motherboard now, but if anyone has any other ideas or can narrow it down further, that would be a great help.
If you decide to RMA your motherboard, let me know if that fixed your problem because I'll probably do the same.
Do you have another PSU to test it with?
Generally every time I have run into what I thought was a mobo problem it turned out being a PSU related issue..
Brief update. . . the board is being RMA'd. Asus tech was fairly responsive and issued an RMA within about 5 minutes (I had already tried all of their suggestions before calling). Although Asus does have a cross-shipping option (you have to ask them for the option), they apparently did not have the Asus A8N-SLI Deluxe in stock for cross shipment.
I'll update this thread once I receive the board with the results and Asus turn around time on a standard RMA.
Thanks again for the responses.
Chris
