Dead Asus A8N-SLi?
45kicks
I have a question, and I hope I am wrong.
I have an Asus A8N-SLi Premium, and I recently picked up 2 9600 GT's for a reasonable price just for kicks to put in there (upgrade from 7900 GT). Well it worked fine for the last 2 weeks, but every time on boot I would get the "EZ-Plug" warning that shows I don't have the 4 pin connector plugged into the mobo just over the primary video card. Everything was working fine without it plugged in, but I would get that stupid warning on startup and have to hit F1 before the system would boot.
SOOOOO i get the bright idea to plug that in tonight to get rid of the warning. I plug it it, fire the system up and....wait for it...no boot. WTF.
Long story short, I can replicate the problem on 3 different power supplies. It seems when I first plug the power supply in, turn it on, and hit the power buttom, all the fans will start for second, then stop. Hitting the power button after that does nothing until the power supply is disconnected, then hitting the power button will start the fans for a second, but they will start right away and not start again until the power supply is disconnected.
All the light on the motherboard are working, and there are no warning beeps on startup.
Any thoughts?
Yeah, but I can try it again later, I am pretty burnt out on trying to fix this honestly. I pulled the battery for the CMOS and will try again tomorrow along with any other suggestions.
Thanks.
I have the OCZ 700 watt modular one, I think the Modstream-X. I know the review on [H] wasn't great, but it was $40 and should run fine at the lower wattage I am using it at, just my athlon 3800+ and 4 harddrives, and 2 9600 gt's.
I have a A8N-SLI Premium which I have been messin around with recently, there is an option in the Bios for SLI mode, it has the choices of Auto (default), Single Video Card, Dual Video Card. Try setting it to Dual Video before putting the connector in. The Options are in Advanced > SLI Configuration > AI Selector.
I've been having problems with that board and getting it to properly power a 16x slot geforce 9400 and a 8x slot 3ware controller card at the same time, it wouldnt even detect the 2nd card slot until I forced it to dual video, and after that was still having problems. I suspect that the dual pci-e is just flakey in that generation of motherboards.
Another thought... There is also an option in there to disable the EZ-Plug Warning, not really a fix but..
lol, maybe I wasn't clear. Currently, when I flip the power switch on, everything turns on for a second - fans hard drives etc, but then immediately stops. The lights on the motherboard stay on but nothing else. I don't even get to the post. Pushing the power button again results in nothing until I unplug the power supply, and which point I can hit the power button again, get power for everything again for a split second. Still no post.
I think there is a short somewhere, and teh mobo is fried, which totally sucks. Oh well, thanks for the advice guys.
I toasted my A8N-SLI the other day after plugging in a TV tuner card that worked fine in another PC. Now I've got an operton 160 just sitting there doing nothing :(
Try unplugging everything that is not necessary to boot. Take out one of the cards and unplug all of your hard drives and see if it will boot then. If it does boot, try with all the hard drives, but leave the second video card out. If not, swap the video cards and try again. If it STILL doesn't work, and you are sure it isn't the power supply, then there is a very good chance the mobo went bad.
Yeah, gonna try this tonight. I pulled the battery for the CMOS yesterday and am going to let it sit for a day just to make sure I am starting completely fresh.
Thanks for the all the ideas guys.
