{ROW}Apocalypse
- Sep 30, 2005
I am having a little trouble with my graphics card. I was playing a little C&C Generals on Saturday, Everything was running well for about an hour and a half. I jumped out of the game to check the GPU temp as the room temp was about 90 degrees. The Nvidia control panel reported 77 degrees celuis. This is a little higher then I normally see but I didn't think it was too bad.
I then took a short break. When I came back I loaded up Generals which all worked fine until I got into the map. I got extreme texture corruption right away and the game locked. Alt-Ctrl-Del got me a BSoD that reported the driver had crashed. After a restart Windows came back up without any trouble. I tried running Dxdiag to see the status of my video drivers. The D3D tested restarted my computer. I then removed and reinstalled the drivers from safe mode and restarted. When I restarted I got video corruption on the boot screens and in the BIOS. Windows loaded to even more corruption.
I have tried the card in a different computer with the same video corruption even before Windows loads. I installed a POS AGP card (S3 Savage4) and it works without any trouble. Is there some program I can use to test my GPU and the memory on the card or is it just dead? Thanks for the help in advance.
Core system specs are as follows:
Motherboard: DFI LAN PARTY NF2 ultra B
CPU: AMD Athlon XP 3000+ (Barton)
RAM: 1024 MB (512 X 2) Kingston HyperX DDR400
Graphics card: eVGA Geforce 6800 (dead?)
Cooling: Koolance EXOS liquid cooling system (CPU only)
