De Vinyl dye my drives?
nightanole
Well as all things go, the drives stay and the mobo and case go. Now i have black vinyl dye drives and a silver case. Other then stealth moding, is there away to remove the vinyl dye so i can dye them a diff color? By the time i got enough coats on the black to turn it silver/white or some other light color, the paint will be too thick and look really bad.
Most paint strippers are pretty harsh on plastic, might want to try something "organic", sanding might be too rough for it too. Maybe experiment on a blank cover fist and find something that works.
Supposedly you can just re-dye the plastic into white and then use that turn as step to make it into any other color you want. I don't think it should build up as you say it will since the paint itself actually seeps itself into the plastic.
would NOT recommend sanding, once the dye is dry, its part of the plastic, so when you sand, your just damaging the surface, wont help it "Stick" any more.
Also don’t paint over it with anything but other dye, if you spray-paint, your essentially sealing where the dye is going to soak in to.
Remember, Dye != Paint !!!!! Paint your adding a layer of color over something, with DYE your actually coloring the plastic, so it doesn’t build up (Once it soaks in)
Another option would be to use Krylon Fusion, that’s paint specially formulated for plastics.
I would just try and re-dye it first. I've seen the maroon palstic parts from inside a Chevy truck died white. I never thought it would work, but it looks great with his white carpet and white w/black piping seats.
